Results 1 to 10 of 10
Thread: Can my pool store be 'really' wrong
    Jun 2011
    Northern Maryland (near Delaware)
    170
    Ok, did some simple tests last weekend with TF100 and took sample to pool store. Variable is a 20 minute ride to pool store with sample
    My #'s
    FC 6
    CC 0
    PH 7.5
    ALK 100
    There #'s with Lamotte tester
    FC 2.1
    CC 0 a match
    PH 7.8
    ALK 110
    CYA 110
    So why would I with drops be 3.9 ppm higher and ph .3 lower. I put a scoop of that powder in the vial at 10ml, could I be putting too much, are my drops to small(doubt it). My test with the Taylor FC/PH test was > 5 which leads me to believe my drop test is right. Can FC drop that much on a 20 minute ride in Air Conditioned Car? Store clerk saw me buying liquid shock (12%) and told me that I would raise PH by using that? I used to be in several times a week buying shock, now I have not shocked since going BBB, though I have not added Borax either, still uncomfortable with that. When I had a slight tinge of ping in my CC I spiked the chlorine overnight, not sure but I am adding about 20 oz a night and testing the next night and hold about the 5-6 range. Not sure what it is at in the am but I am guessing 6% takes me up 1 ppm.
    Now for vacation, should I add 2-4 oz of PolyQ 60? I usually do 2 oz a week and have a neighbor watching the pool who also has pool.
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    30,415
    Re: Can my pool store be 'really' wrong
    When you get a chance, search for "Trust your own testing" on this forum. You should get about 10,000 hits!!
    Please trust your results and disregard the pool store tests. No one at the pool stores cares about your pool water like you do and perhaps no on there even knows how to test as well as you do.
    In short, trust your own testing.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,589
    What duraleigh said. Period.
    May 2011
    Clearwater, FL.
    446
    I had the same problem, I was mixing results with the pool store. BAD ME!
    Quit going to the store and just relied on my TF-100 and BAM! My pool did exactly what it was told to do.
    Perfect all the time now, I did find the sweet spot after about a month.
    My pool likes the TA at 80-90, my ph stays right on 7.5 all the time. When I had my TA up at 120, the PH would be swinging up a lot.
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Did the pool store rinse their vial with fresh water then pool water before testing? Did they carefully hold the reagent bottle upside down to be sure drops were uniform? Did they use a test strip, then run it through a black box that gave overly precise values?
    Trust your own testing.
    Apr 2008
    Central Texas
    326
    Those pool store results aren't even THAT far off. This spring I tested my water just before a trip to the pool store to buy some DE for my filter. Just for giggles, I let them test my water. PH was dead-on 7.5 and CYA was 40 by my results. They came up with a PH of 8.5 and a CYA of 80. Of course they wanted to sell me some acid and a (really expensive!)miracle bottle of Phos-free to solve a problem that I didn't have.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Feb 2008
    Dallas, TX
    60
    Supertune summarized it very well. Rely on your testing and your results and your pool will behave predictably: trouble free!
    31000 Gal IG L-shape w/ spa, Riversand finish (PebbleSheen clone)
    Jandy 60 sq ft DE, 2.5 HP (uprated) Stealth pump, Polaris 280 w/ booster, Jandy PDA PS4 controller
    Jul 2011
    Central VA
    14
    Quote Originally Posted by supertune
    Whoa -- kinda OT here, but your signature caught my eye! What did you get in place of the 'A' cartridge? Curious.
    Central VA
    My 'disposable' pool -- 7600 gal 18' round AG Intex Ultra Frame, Intex sand filter
    Took it down the first year, but it has been up year round for three years now
    Was really hoping last winter would have done it in so I could justify an upgrade!
    May 2011
    Clearwater, FL.
    446
    Quote Originally Posted by jnd5309
    Hi jnd5309,
    Go here and read my posts on what I did:
    Chuck
    http://www.troublefreepool.com/custo...ls-t28971.html
    http://www.troublefreepool.com/intex...le-t35091.html
    TF-100 test kit
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Pool stores survive - nay, THRIVE, on inaccurate testing. The worse their accuracy, the more money they make. It is little wonder that they do not strive for continuing excellence on stringent cleaning and testing methods.
