Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: New Pool Owner, New to BBB, Test Results
    Jul 2011
    Covington, TN
    16
    Hello,
    My husband and I bought a home with an inground pool that had been neglected. We had a new liner installed and the liner man opened the pool. We know nothing about maintaining a pool! I have carefully studied the BBB method in Pool School and I am almost ready to attack our problem pool! Current equipment is a cartridge filter but the cartridge has a hole somewhere and we are installing a sand filter tomorrow. Our current issue is algae, the pool is now a lovely shade of emerald! Blah!
    I will be beginning BBB with the shock process tomorrow afternoon when the new sand filter is up and running.
    I have purchased the Leslie's version of the recommended test kit.
    Any advice is appreciated! Thank you!
    Current Levels per the Pool Store's tester:
    FC: 1ppm
    CH: 150
    CYA: 30
    TA: 80
    pH: 7.4
    Phosphates: 500ppb
    Is the high phosphate level a cause for concern? Pool Store Guy talked about PHOSfree but I really don't want to add anything like that, especially until I get the BBB method running nicely.
    29,100gal, sand filter, IG, vinyl
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: New Pool Owner, New to BBB, Test Results
    Ignore phosphates
    Re-run the tests (especially CYA) with your test kit and begin the shock process
    oh yeah, welcome to TFP
    Jul 2011
    Covington, TN
    16
    Thanks for the help!
    I re-ran the tests with my new kit and got...
    FC:1
    CC:1
    TC:2
    pH:7.5
    TA:100
    CH:70
    CYA: <30
    I couldn't get the CYA test to obscure the dot at all. Are the differences in the values because I'm new to this or because my test kit will read differently from the store's?
    Butterfly's Avatar
    South Carolina
    10,045
    Always trust your test results over a pool store
    Do you know how much CYA you added and when? If you know, then we can help you calculate the current level.
    Have you seen this visual of the CYA test from Taylor? Scroll down to see pics:
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    Have you found the PoolCalculator.com?
    Welcome to the forum
    You're done SLAMing when:
    Jul 2011
    Covington, TN
    16
    I have not officially added CYA as a separate ingredient, although I have used tablet type chlorine since opening the pool in early May.
    I have found and used the Pool Calculator. It is a great resource and very easy to understand!
    Thanks!
    Sep 2009
    Greentown, IN
    914
    Sounds like you're well on your way! Take some pics to show your progress... we love pics here!
    Once you start the shock process, stay with it and it will clear up faster.
    Enjoy your pool!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    May 2011
    Clearwater, FL.
    446
    Hi and welcome to TFP!
    Just remember... during the shock process, you must maintain your level of shock all the time and not let it fall below that # until you pass the 3 criteria in Butterfly's sig.
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jul 2011
    Covington, TN
    16
    The sand filter is up and running nicely! I have begun to shock the pool by adding the recommended amount of 6% bleach. I have a problem with my new test kit though...it will not register the goal shock level of FC: 12. My kit (that I thought was a good one!) only reads up to 5! Should I be taking my samples back to a store to check my level? If I do, will my early morning sample stay "good" until the store opens?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Leslie's sold you a Taylor K-2005 instead of the K-2006. The kit should have a powder/reagent chlorine test, not R-0001 and R-0002 used with a color block.
    Shame on them! Take the kit back, tell them it's old and useless and they stole your money.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2011
    Covington, TN
    16
    Quote Originally Posted by frogabog
    AARG! Thanks for the info on the kit. I was looking at the K-2006 trying to figure out how mine differed...
    Problem...not realizing this test kit mix-up, I began to shock. I live an hour away from the store that sold me the kit and there is not another location closer. Is there any way I can maintain this shock process until I am able to get back to the store tomorrow? I would really hate to have wasted all that bleach. Especially since I am trying to get DH on board with the BBB plan.
    Just wanted to say a HUGE thanks for all the help so far. This board is an amazing resource, especially for a total newbie!
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Someone here knows a good way to guestimate shocking for you till you can get the kit replaced. Around here, the H's answer would be to just dump loads of bleach in regularly. Do not ask me to quantify "loads"... It would likely involve whole bottles, lol.
    Maybe look through some of the threads that have described their shocking numbers, guess (+ a bit more to be sure) from the average losses people report?? i.e. if many people report loosing 50% of the chlorine in the first two hours, and then 30% the next two hours, assume you will too and dose accordingly.
    The worst that can happen is you over dose or under dose a little tonight although neither option will be the end of the world. If you under dose, you might loose a few hours of the process but you won't loose as much as if you dose once and then do nothing afterwards because you can't test. As long as you're not adding more than the mustard algae shock level you can't really hurt the pool with overdosing so that is even less worrisome.
    Jul 2011
    Covington, TN
    16
    All is not lost! The store does not close until 7pm so I am heading out now to get the "Service test kit" aka the k-2006. Now lets see how their return policy works because I have used this kit already.
    Jul 2011
    Covington, TN
    16
    Well, after making a flying trip to Memphis because the Leslie's guy said they had the kit in stock...they didn't! And the manager actually asked me "so, what's the difference in the kits and why do you need the other one?" sheesh. I ordered a Taylor 2006 kit and I hope it arrives quickly. Until then,'I'll be researching the guesstimatons and trying to keep my shock level up.
    I brushed my pool today and the algae made a nasty cloud. Hopefully my filter will be able to take care of everything I stir up.
    Any additional advice on shocking by approximation?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Someone else should answer this but what about dosing to shock, and then adding 2-3ppm every hour for as long as you can tonight?
    Not sure what to do in the am, I'd probably dump enough in to go from 0 to shock as soon as you wake up, and then do the 2-3ppm route every hour or two all day long. It's a stab in the dark, and if this isn't a good idea or 2-3ppm/hr isn't a good hourly guestimate I sure hope someone else will tell you what to do.
    You can try it, and if the pool looks different tomorrow you can assume you're doing ok till the kit arrives. It might take more than a day to see big results but if shocking is working, you really should see "some" kind of difference in one day even if it's just a small change.
    22,551
    If you have an OTO kit you can dilute the pool water sample half and half with chlorine free water and multiply the results by 2.
    Jul 2011
    Covington, TN
    16
    Thanks Bama Rambler, I'll do that for now.
    I added more bleach before bed and lo and behold the water is bluish and milky this morning! Its sad that I'm excited about that but it looks much better than green!
    I tested with my OTO kit when I got up and got about a 2ppm so I used the Pool Calculator and added enough to bring it back up to 12 ppm (my shock level). Now that I know I can use my OTO kit until the good one comes in, I'll be able to monitor my levels hourly.
    Thanks again!
    22,551
    The biggest thing is to keep after it. Once your kit arrives you can test and then run the OCLT once you're close enough.
    Jul 2011
    Covington, TN
    16
    OK, the kit is in ( ) and I took the plunge tonight to thoroughly vacuum, brush, etc. Stirred up lots of mess but I think the filter can handle it now. I also added some clarifier (I know, I know!) because I'm in a hurry to clear up this mess.
    My first test results with my new kit are...
    TC 3.5
    pH 7.6
    TA 100
    CYA- very low
    In my excitement, I forgot to do the CC.
    Back to raising that chlorine level. I was surprised at how much fun using the test was! Lucky me, I get to do it again before I hit the bed at about 1am.
    If it is cloudy but I can see the bottom, would it be ok to have people swim? The youth group from Church wants to come tomorrow afternoon. I know I will have to be sure my chlorine is at a safe level to swim and that will set me back some on my shock process. Anything else I'm not taking into consideration?
    If you cannot see the bottom you cannot see a child on the bottom. If it is cloudy now it will be more so with chlorine levels lower and people in the pool. Be very, very careful. If you do this you should be prepared to test and clear the pool to add chlorine if needed,allowing 30 min to circulate.
    Or,the clever idea someone posted, have everyone run in the same direction to stir the water into a whirlpool, then pull them out to add chlorine. Mixing should be done in minutes, I'd guess.
  20. Back To Top    #20
    Jul 2011
    Covington, TN
    16
    Thanks for the reply. As of this morning I can see the entire bottom including the main drain area at the deepest point. It is slightly hazy but much improved. Test results show that I still can't pass the OCLT but my CCs are at 0. ph is a little low due to the dichlor I guess. I'm going to adjust before they get here and I'll use the great whirlpool idea when we drag them out for lunch. They'll be out for 30-45 min so it should have plenty of time to mix then.
    I'll try to get some pictures up today too!
