Thread: Sand filter leaking at clamp
    I have a Hayward sand filter with the multiport valve at the top.
    My pump motor went bad, and my pool was down for a week and a half before I got the new motor installed. The pool is dark green. I backwashed the filter - water in the sight glass was white as usual. After it cleared, I turned to rinse for a minute or so. Finally, I turned the valve back to the filter position. When I turned the pump back on, water was spewing from the clamp joining the valve to the body of the filter. The leaks shoot out right where the two bolts are. I tightened the bolts until I was afraid I might break something, but the leak persisted. I loosened them again and tried gradually tightening, but the leaks don't improve.
    Note that the new pump motor is slightly more powerful than the old - I will give details if anyone thinks that's important.
    South Central NJ
    3,192
    Re: Sand filter leaking at clamp
    Check the O-Ring between the tank and multiport.
    Scott
    Owner of - PoolGuyNJ LLC
    Do I just remove the clamp, detach the three pipe connections, and lift the valve off? How does the the valve connect to the internal piping? Will I be able to just slip it off?
    22,544
    It will just slip off the center pipe inside once you get the external piping off. Be sure to lift straight up. Also put plenty of lube on the new seal.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
