Results 1 to 10 of 10
Thread: Milky water. Had a major green algae bloom
    I killed the algae and now I have milky water. I run an intex 18X48 AGP with intex's sand filter and Krystal Klear SWG.
    Should I add a bit of bleach or empty a portion of water out thru Backwashing.
    Total noob regarding pool chemistry.
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
    I don't know the the filter info other than it's original equipment (1988) and the Pool Guy laughed when he saw it. My husband has repleced the motor a few tmes with the (Anthony Pool)recommended pump size.
    Re: Milky water. Had a major green algae bloom
    How did you kill the algae?
    Algaecide from walmart. Used the recommended dosages.
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
    I did the same thing last year, seems like the milkiness lasted forever. This year I kill the stuff with bleach, and I catch it early and attack it hard!
    I'm sure someone will come along with more info on your situation. Have you checked out the Pool School tab at the top of the pages. Very good info there to get you started on pool chemistry!
    In my opinion, the Intex pools need to be used often, daily if possible. People do a better job of circulating water than the pumps, which ensures that any of the little green meanies will be mixed into the chlorinated water, rather than lurking in stagnant areas.
    22,539
    You need good tests in order to keep your pool clear. You should follow the recommendations in Pool School for a small/temporary pool and the levels for a swg. Post a full set of test numbers and how you go them.
    bought Aquachek Salt test strips and FC test strips from local pool store.
    Salt strip reads 2190 ppm
    The other strip reads
    PH 7.8
    FC 0.5
    TA 120
    Stabilizer 30-50
    Hope this helps
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
    22,539
    The salt strips are ok but the others aren't. Spend some time reading Pool School and learning how to take care of your pool. A good test kit is an investment in your family's health. I'm not sure you've killed all the algae yet and without a good test kit you can't tell if there's anything still living in there. Till you can get a good test kit, take a sample to the pool store and post their numbers.
    Looks like you need to add some salt.
    Here are my pool store test results. They were out of their test kits so I bought a 3 way kit from walmart HTH. Im sure that is not adequate but for now at least I can check chlorine, bromine and PH
    CL 1.32 (he also gave 1.60
    PH 7.78
    Calcium 180
    alkalinity 91
    stabilizer 12
    Salt 2230. He recommended adding 40 more lbs of salt which I bought and dumped.
    He said the filter would handle the cloudyness, but its a slow process.
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
    Your CYA level is way too low for use with a SWG. I would be a little cautious, since your CYA level test results are inconsistent and probably not completely reliable, but it still looks like you need to raise CYA significantly. The ideal CYA level with a SWG is around 70 to 80, but err a little on the low side of that because of the unreliable CYA test results and the difficulty of lowering CYA.
    It can easily take a sand filter a week, or more, to clear up cloudy water after the algae is all dead. It isn't clear if your algae is all dead or not, but assuming it is, you should see a visible improvement in the water each day.
    Success at last, Finally got a handle on the milky water, its clearing up very nicely.
    Thanks for all you do and your advice.
    BTW, this will be the last EasySet Pool I buy. For now on, Bigger and better,
    (And the lazyman way of doing pool care, HELP WANTED, LOCAL POOL SERVICE TO CLEAN AND MAINTAIN A BUSY FAMILY'S POOL. )
    kidding.
    Joan
    Baltimore MD
    22500 IG Plaster
    DE Filter
