Thread: Wanted a denatured alcohol fire feature but......
    Hi All,
    I see all these shows on DIY etc and they have these denatured alcohol fire features. Seem pretty cool and look good with no running of gas pipes, digging trenches etc. I did some research and the ones I were looking at were $2K and higher Am I just shopping at the wrong place or is that the going rate? Either way I'm not paying it and don't know who the **** would.
    Any ideas?
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Re: Wanted a denatured alcohol fire feature but......
    I haven't seen what you're referring too, but I did just stumble upon this that might be similar to what you're looking for:
    http://www.outdoorrooms.com/store/fire- ... fires.html
    19,000 gal gunite/plaster in-ground pool w/spa, built May 2007
    Pentair Intelliflo VF pump
    Pentair CCP420 cartridge filtration
    Pentair Intellichlor IC40
    UltraPure UPP50 ozonator
    Intellitouch control system
