Thread: Pool Filter PSI
    Pool Filter PSI
    I have a question about pool filter cleaning and PSI. What should the PSI on the filter be? Also how often should you clean the filter?
    My last test results are
    FC=1
    CC=.5
    pH=7.2
    TA=160
    CH=410
    CYA=75
    I added bleach to bring up FC and will test again tonight. Water is clear.
    14,000 gallon IG plaster pool, Cartridge Filter
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pool Filter PSI
    Filter pressure can have a wide range of acceptable values. It depends primarily on the size of the pump and the size of the pipe.
    As for cleaning, the rule of thumb you see on many sites is to clean the filter with an 8-10 PSI rise but to me, that is way too high and can substantially reduce flow rates. I would clean a filter before it rises more than 25% from the clean value and preferably at 10%. However, if you have a small filter, that could mean you would be cleaning it a lot. So you have to balance the cleaning frequency with pressure rise. I clean my filter 1-2 times a year and there is barely any PSI rise but I oversized the filter which allows me to do that.
    Mark
