Thread: cloudy/green water - help
    Split from cloudy-green-water-help-t35310.html Butterfly
    Quote Originally Posted by woodyp
    The only "professional" product you should need to clear your pool at this point is good old 6% household bleach. Read shocking your pool in pool school. Run the pump 24/7 and backwash it as needed. Welcome!
    I seem to be having the same issue this year for some reason. The green changes to milky then almost clear then back to green by the end of the week. All I use right now since I found this website is 5.25% to 6% bleach, depending what store I'm at for the bleach. 3/4 gal at the Dollar Tree is 5.25% and the Walmart/grocery stores in the area carry 6%. The Ph is at 7.5-7.8 but I only use the test with the red drops and yellow drops for Ph and Chlorine. So if your correct, I should be using more chlorine to get my 13,000 gal pool clean? I use 1-2 gal a week but it just doesn't seem to be working. My pool is in the sunlight most of the day. Not sure if that needs me to add more chlorine. Help?
    13,500 Gal, 24' round AG pool with 22'' sand filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: cloudy/green water - help
    Read the Sticky!
    You need to overwhelm the algae with chlorine to kill it faster than it can reproduce. Once it's all dead, it will only take minimal amounts of chlorine to keep it clear. But right now you're just see-sawing back and forth over which side is winning: algae or bleach?
    Bleach from some dollar stores can be old and not strength as advertised, keep notes to see if quality between sources varies. Are you adding a little bleach daily?
    Quote Originally Posted by anonapersona
    No I don't add daily. Didn't think I needed too. Used to do once a week when I was spending all my money at the pool store. Now I'm looking to go BBB method this year. So you think daily is a good idea? How much daily? I don't want to come out of my pool a blonde. lol (jk)
    Forgot to add, I started using a solar cover this year. good or bad?
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by dfarrarjr
    How much depends on what your test kit says.
    I think it's time for you to visit Pool School
    Sep 2009
    Greentown, IN
    914
    Most people will have to add chlorine daily.. even if small amounts to keep the levels w/in range for their Cya value.
    Do a good read of the pool school and while your there look at the "how to shock" area. If you're fighting algae.. it will give you what you need to know to win that battle.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
