Thread: Best place to buy parts?
    Mar 2011
    Houston, TX
    72
    Did my first cleaning today on the filter and there are a few filter parts including new filters I want to order. What is the best place online to order? I only assume I can find cheaper prices online. Was quoted 73.99 for each filter at the local pool store. Need an o rings for the air release valve for the Jandy 460 filter. Lastly I noticed the manifold assembly has a crack in it. So I will need to order several parts. Where should I look?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Best place to buy parts?
    Look under Supporter Specials on the main forum index.
    Also, there is some advertising on Pool Calculator, I imagine there's some sort of kickback if you access them through Pool Calculator, which helps keep it online.
