Results 1 to 11 of 11
Thread: My wife installed an 18-foot Intex pool on a slope !!!
    My wife bought an Intex 18 foot x 52 inch Round Ultra Frame Pool from Toys"R"Us last Friday and by the time I saw it she already had it set up on our brick patio and filling with water. Our patio is on a slope so that the highest end of the pool is about 10 inches higher than the lowest end. I think this means that the slope is just under 3 degrees. Now the pool is already full of water and the weight of the water is causing the metal posts around the edge of the pool to lean slightly towards the lowest end but nothing is broken at this time. There is a warning on the side of the pool saying "NO SLOPING GROUND" so please let me know if you think this pool is in danger of collapsing.
    Thanks in advance for your responses.
    Desperado
    Greg78's Avatar
    Jun 2011
    N Ft Myers, FL
    13
    Re: My wife installed an 18-foot Intex pool on a slope !!!
    Yes I would say it is in danger of collapse. I've seen recommendations by other posters that up to 2" out of level is acceptable. My personal pool 16' x 48" Intex Ultra Frame is just under an 3/4" out of level, it was quite a bit of work to get it that close but it is worth it.
    Intex Ultra Frame 16' X 48" (5,000 Gallons)
    Intex Sand Filter System (2650 GPH)
    Taylor K-6000
    BBB
    22,469
    If it was a couple of inches I'd say it was ok but at 10 inches I'd have to say you need to drain and move it or make it level. I wouldn't chance leaving it.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    agreed!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    To much of a slope!!!
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Jun 2011
    Cape Girardeau, Mo
    125
    I would drain it as soon as possible i saw one a couple of days ago in my neighborhood that was on alot less slope than yours that had bent the post in half ...i would condider it dangerous.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Quote Originally Posted by Desperado
    Desperado
    I know just about everyone on this forum will disagree with me on this but my pool has been up for 4 seasons and is about 4 inches off and has been fine. My sister inlaw's is about a foot off and her's is the age as mine and has never been taken down and hasn't had a single issue. Not even any rust on the frame! Personally I just don't like the pool to not be level... I'm kind of OCD like that so next year my new pool has to be perfect! Good luck on your decision!
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    Apr 2010
    Western North Carolina
    44
    The pool (18' X 52") holds 7600+ gallons of water. That's 63,000 lbs. of water. I wouldn't want that on my conscious if it collapsed on someone.
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Not worth the risk
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Take it down and do it right, there is personal safety of everyone around you involved as well as personal property, your exceeding all pool manufacturers recommendations and just because there is no failure today doesn't mean it won't fail tomorrow.
    As tmyers said, contemplate the weight in that pool and what it can do to your loved ones....or what your neighbours lawyer will do if his family/ property are damaged.
    Thanks everyone.
    I've drained the pool and now we're thinking about moving it to another location. The new location is almost perfectly level but it's located right above the slope that the house is sitting on. Under the house is a large air conditioning and heating unit as well as the wiring which provides electricity to the whole house. So if the pool collapses it can cause a lot of damages or get somebody electrocuted.
    Is this something I should worry about or is it almost impossible for this type of pool to collapse when properly installed ?
    Desperado
