Results 1 to 11 of 11
Thread: Broke off return eyeball
    Oct 2010
    Temecula, CA
    122
    In an effort to fix one of my returns, I accidently broke off the piece completely. There is still some part of the piece stuck in the pipe. Any recommendations for getting the remaining piece out easily and, in the meantime, is there any reason I cannot run the pump? It's not going to do any damage until I can repair this, I hope?
    Thanks!
    Anne
    Temecula, CA
    16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide
    Whisperflo pump; Pentair SMBW 4000 Series filter... that's all I know! Still learning....
    30,421
    Re: Broke off return eyeball
    Won't do any damage at all. Not sure about how to get it out. Did the rotating eyeball break or the part around which the eyeball rotates?
    Oct 2010
    Temecula, CA
    122
    The part around it broke. The only way I was able to move the eyeball was to loosen the bigger piece around it. I was playing around trying to get the eyeball in the right position, then tightening the piece that holds it in place and the whole thing came off in my hand. I stuck my finger in the return and it feels like there might be leftover pipe stuck in there that might be able to be unthreaded but I can't tell.
    Temecula, CA
    22,550
    You're most likely correct. The fitting most lilely broke off at the threads. It shouldn't be too hard to remove it.
    Mar 2007
    Coastalish 'down easter'
    4,160
    If it's a Hayward inlet, SP 1419-T is the tool to remove it. Or you can use a pair of needle nose pliers to grip the slots on the inside of the fitting to make it come out.
    If this gives you a lot of trouble, let me know
    Luv& Luk
    -Ted
    Oct 2010
    Temecula, CA
    122
    Can't tell if it's Hayward - would it say something on it? Here's a few photos. I was not able to loosen with needle nose pliers - hopefully DH can do it but if I can get a tool and not bother him, he'd be happy. lol
    Thanks for any help.
    Temecula, CA
    Aug 2007
    near the swamp
    806
    if there's grooves or slots on the inside, you can use the fan blade of small putty knife to get it out
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I used a washer and vice grips on mine. Used the washer to grab the notches and use the vice grips to turn the washer.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by waste
    Or a 1"1/2 wood chisel :0)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    4,160
    Kevin, that's why you're the X- Pert
    Luv& Luk
    -Ted
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    I had one broke like that for years never could get it loose with brute force. Finally this year, with the water level below the level of the discharge I used a dremel tool to cut down just to the first sign of the threads. Cut in three places then it popped right out.
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
