Thread: Very first time in my life adding Chemicals to a pool!
    Jun 2011
    Dothan, Alabama
    24
    I'm feeling a little scared. I don't know what in the heck I am doing, and the warning labels on my chemicals have me scared to make a wrong move. Ok. It says I need PH Down, Calcium Hardness Increaser, Shock Plus, and a Chlorine Tab. I only have the tabs, and shock plus. So, I'm heading to Lowe's to get the rest, and also to get a floater for the chlorine tab. I'm a little confused as to in what order to add these, or do I have to wait to put them in seperately, or can I put them in back to back? Also, how long do we need to wait to swim after using these? The shock plus, says you can swim within 15 minutes, but not sure about the others? Thanks in advance for help.
    Intex 15x42 Metal Frame Above Ground Pool
    3861 Gallons
    Krystal Clear 637R Filter Pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: Very first time in my life adding Chemicals to a pool!
    Do you have any testing results you can post for us so we can help? Can you tell us about your pool and equipment like mine shows below? Just go into your profile and add a signature line. If its a vinyl liner pool, you don't need any calcium. Do you have any CYA? We suggest using muriatic acid to lower your PH if necessary. Depending on pool size, I'd recommend adding some good old liquid bleach 6% to your shopping list to get started. Have you read pool school first?
    May 2011
    Woodslee, Ontario Canada
    26
    Can you post your test results as well as the size and type of pool you have. Many people here to help and put you at ease.
    14X28 inground Vinyl
    1HP Super II Pump
    200lb Sand filter
    Tri-chlor, bleach shock
    BBB
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by threewide
    ...size and type of pool you have.
    In the poster's signature:
    3861 Gallons
