Thread: Cloudy water with SWG
    Hi Everyone - Happy 4TH -We have a new Intex metal frame 12 x 30 pool (2100 gal) with SWG. Have been to Pool School & purchased the TF 100 as recommended by the community. I've only had to run the filter (1000 gph) for 3 hours & SWH x -1-2 hours & the pool has been crystal clear. Now the pool has been cloudy x 2 days - the measurements are as follows:
    FC 4
    CC .5
    TC 4.5
    pH 7.5
    CYA 60
    TA 130
    CH 100
    I changed filter the ran the pump all night - it is still cloudy Any ideas on the problem?
    Feb 2008
    Denton, TX
    5,061
    Re: Cloudy water with SWG
    I would go ahead and shock your pool with bleach and let the filter continue to run. Tonight, after the sun sets, check your FC. Check it once again in the morning before the sun comes up and see how much FC you lose overnight. If you lose more than 1 ppm of FC or your CC is greater than 0.5, continue to shock.
    May need to run the filter longer also. I run my filter 12 hours a day. For intex pool that may be 12 hrs less the time swimmers are moving water around.
    Thanks - the pool is clear, I hit the boost on the SWG to shock it & it ran for 8 hours - but it says to measure copper because it will turn blonde hair green if copper is too high (have 5 blondes here) - I have the Intex texst strips, but the chlorine test strips are so unreliable that I am not comfortable with their copper test strips. Where can I find a reliable copper test kit? I thought to avoid boosting with copper ions, I would shock it with OTC bleach (is that a good idea?) - how much bleach would I have to use for a 2100 gallon pool? How long do we have to wait after putting bleach in to shock do swimmers have to wait?
