Thread: Should I lower TA?
    Should I lower TA?
    My TF-100 tells me that my TA and FC are a bit high, and my pH is still low. I've cut back on SWCG runtime, and started aerating to raise pH. Should I also lower TA, or is 90 OK?
    TF-100 readings:
    • FC - 7.5
    • CC - 0.5
    • pH - 7.2
    • TA - 90
    • CH - 80
    • CYA - 25 (new pool, still adding stabilizer)
    • Salt - 3400
    Sim
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Should I lower TA?
    I wouldn't bother going to any extra pains to lower TA. If you're aerating, pH will come back up pretty quick, and then when you add acid to lower pH, TA will also be reduced. Unless you're adding a lot of high TA fill water, it should settle down by itself in a couple weeks.
    Feb 2008
    Denton, TX
    5,061
    Also, understand that as long as you are running a SWCG, pH rise will occur moreso than it would if you were running a straight chlorine setup. It's just part of the process.
