Results 1 to 19 of 19
Thread: First TF-100 Test Kit results, comments?
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Great forum, very helpful, thank you in advance. I drank the Kool Aid after quickly realizing the pool store was a dead end.
    First TF 100 Test Kit results yesterday:
    FC 11.5
    CC 1
    TC 12.5
    pH 7.5
    TA 70-80
    CH 230
    CYA 60
    Temp 86
    Salt 2800 per test kit (my Jandy monitor reads 2100)
    SWG 40%, Pump run time 8am-6pm daily. Waterfall pump runs 30 min twice a day as well. I sometimes keep one Tri Chlor puck in the spillway area since it isn't filtered as often as the pool. I did have a big pool party the day before, so I slipped 2 TriChlor pucks in the skimmer the night before these reults, likely explains the elevated FC level.
    Any comments very appreciated.
    Enjoy Independence Day, I'm at work, but home for fireworks!
    Dave
    Charleston SC
    10K flush deck Infinity Edge with whirlpool spa, Pebble Tec finish, SWG, DE Filter.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Re: First TF-100 Test Kit results, comments?
    A CC of 1 would indicate that a shock process is in order. How is your water looking?
    Congrats on getting the test kit... it is the number one key to having control over your pool.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Water is clear. I do get a slight amount of "dust" when I brush the deeper end of the pool, but no obvious algae. I do clean the DE filter fairly frequently (about every 2-3 weeks) which is too often I understand, but it gets clogged with green/brown material. I did have algae after winter storage and the pool guy advised the tri chlor pucks and running the filter, which worked, but maybe I still have microscopic algae?
    Thanks
    Dave
    Charleston SC
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I guess that is possible or you having something new trying to take hold. A CC reading of .5 is considered acceptable (taking one drop to change your sample back to clear). Anything more than that would indicate shocking. The instructions for shocking are in Pool School, the chlorine/CYA chart will give you your shock number as it relates to the CYA level in your pool.
    27' round AG
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, I suggest you follow dattia's recommendations
    Welcome to the forum
    You're done SLAMing when:
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Thank you all for the responses.
    So plan of action will be:
    Perform OCLT, if positive, shock.
    Maintain shock levels of FC until OCLT is less than 1 ppm or less.
    Additional question: I do have some old evidence of Calcium leaching out from the tiles in spots (mostly where the water runs over the spa into the pool or over the waterfall). I am planning to use dilute muriatic acid to brush off, then raise my CH to 300 to avoid leaching (per article for SWG pools). Thoughts?
    Thanks again.
    Dave
    Charleston SC
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Make sure that your SWG is off before you do the OCLT or the FC it produces will skew your results.
    27' round AG
    Butterfly's Avatar
    South Carolina
    10,045
    Well, I suggest that you start the shock process tonight. The reason is the 1.0 CC.
    And, shocking at night lets 100% of chlorine fight nasties in the water and none is lost to sunlight.
    You can bring pool to shock level, wait an hour to test for FC & CC and still do the OCLT.
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Appreciate the responses. Will shock and perform OCLT. Pump stops at 6pm so SWG is off. Should I run the filter all night when shocking with the SWG off?
    Thanks again
    Dave
    Charleston SC
    Butterfly's Avatar
    South Carolina
    10,045
    It is best if you can run pump/filter 24/7 while shocking.
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Will do.
    Thank you all again.
    Will report back.
    (If pool is unattended for several days, any thoughts on using a solar cover to prevent chlorine loss, keep trash out, etc)
    Dave
    Charleston SC
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by First Pool
    Will do.
    Will report back.
    Lotsa folks do that. Use the google search, bottom left on page, for 'vacation' for good info
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Thanks, will use my solar cover and pump/SWG on timer and maybe a few pucks of Tri Chlor depending on the CYA level.
    Thanks again!
    Dave
    Charleston SC
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Performed OCLT
    7/4 7pm (SWG/filter pump shuts off at 6pm)
    FC 11
    CC 0.5
    TC 11.5
    7/5 7am (SWG/filter pump does not turn on until 8am)
    FC 8
    CC 1.5
    TC 9.5
    Although it is light here at 7am, no direct sunlight. Assume there are organics or low level algea consuming chlorine and hence the rise in CC, therefore shock is in order.
    Comments?
    Thanks
    Dave
    Charleston SC
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I am surprised to see the rise in CC overnight. Shock is definitely in order.
    27' round AG
    Butterfly's Avatar
    South Carolina
    10,045
    Just verifying: Shock level for CYA of 60 is between 18 and 24. Are you reaching shock level?
    I missed part of your Q above about running your SWG during shocking. You can run your SWG during shocking and it can help maintain shock levels, however it is up to you whether or not to run it. The only thing about the SWG and shocking is that it must be off when performing the OCLT, and you already knew that
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    Butterfly and Dattia, et al
    Thank you for the replies. Rained last night, so FC dropped to 4 and CC were at 1.5
    I shocked early this am with bleach per pool calculator, then measured FC several hours later and it was still 27 with CC = 0.
    Brushed a couple times, ran the waterfall pump to mix well.
    Water is "cristal"
    Should I maintain shock levels 24 hours and measure a OCLT in am to confirm?
    And what level of FC is safe to swim.
    Thanks again
    You all are really helpful folks.
    D
    Dave
    Charleston SC
    First Pool's Avatar
    Jun 2011
    Charleston SC
    9
    BTW I am running the SWG and have a trichlor in the spillway just in case.
    Dave
    Charleston SC
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, you should do another OCLT tonight. dad burn rain
    Generally we say it is okay to swim between min and below shock level based on your CYA level.
