Thread: John from Lancaster, PA
    Lancaster, PA
    15K IG Vinyl Pool 3/4hp Sta Rite pump sta rite cartridge filtere blue dolphin vacuum chlorine
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Re: John from Lancaster, PA
    Welcome to the forum, John.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Welcome!
    And let me be the first to say, "Can you post a full set of test results?"
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome
    You're done SLAMing when:
