Thread: Do all return jetss in inground pool push out water?
    We just had a new gunite pool inground pool installed with pebble tec finish. My pool installer is a real beauty and a scam artist. Ive had nothing but problems with him. I need to know the truth if anyone can help me since he left me no brochures on any of our products. I have a hayward filter which he told me must run consistently for 4 weeks without stopping. The salt water filter (tcell) he told me had to wait for 4 weeks to install that (saying it will ruin my pebble tec). Lo and behold he finally came back and installed the tcell and told me to run the filter another 4 weeks non stop. But there is one other thing that im questioning in my head and he told me it was normal. We have 4 or 5 outlets that the filtered water comes out (i suppose they're called jets) well 3 out of the 5 jets the water is barely pushing out 1 of the jets the water comes out with some force and then the last jet nothing at all is coming out. The Jack*** tells me thats normal that you have one jet that the water is not suppose to come out of I ve been in my share of inground pools and Ive never noticed but every jet that ive been in front of has a lot of water pressure . Is there suppose to be a jet that doesnt push water out at all? Should they all have equal water pressure (most of them it barely comes out one has good pressure) We have let the air out of the filter??? And the filter has been backwashed...Could someone with some knowledge of this please help me out this guy is really shady thanks
    HELP!
    Are eyeballs normally standard equipment in gunite ig pools? MY company just left the white pipes no eyeballs on the returns? Can I add them now or should i call company up?
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Do all return jetss in inground pool push out water?
    Welcome to the Forum!
    Wow, sorry to hear that you are having such problems and do not trust your pool builder.
    Please see my reply to your other question: help-t35290.html as they seem to be related.
    Aloha!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    May 2011
    On the border AR/TN
    82
    Re: HELP!
    Let's see: Yes and Yes would be my answer and recommendation.
    Yes to the eyeballs. Adding eyeballs may actually help your situation is your other post: do-all-return-jetss-in-inground-pool-push-out-water-t35288.html
    By adding eyeballs to all the returns, you will create back-pressure that will cause the flow (to hopefully) even out amongst the other jets (returns). Of course, if there is debris or other blockage, then eyeballs will not help the situation.
    And yes, I would recommend contacting your pool builder about the eyeballs. Just in case, please see this thread for "cheap" eyeballs: 1-5-pvc-fittings-cheaper-than-oem-equip-some-lessons-learned-t35286.html the recommendation is at the end of the first (original) post.
    Hope this helps. Enjoy!
    Aug 2007
    near the swamp
    806
    is one of those returns by chance a dedicated return for a pressure cleaner? like a Polaris?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Also, you may have some valves on the equipment pad to control the flow to some of the returns. Post a picture and maybe we can help.
    Mark
