Thread: fresh build slow fill ... when should I begin to add chems?
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    I have some bleach handy for my new pool, but the fill is taking forever ... 16K-17K gallons is going to take 3 days minimum ... should I begin to add chemicals? I should have the skimmer installed tomorrow, so I will be in the water and can broadcast it pretty well ... thoughts???
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    Re: fresh build slow fill ... when should I begin to add che
    Check your contract. Warranty may depend on builders instructions.
    FastCougar's Avatar
    Jun 2011
    99
    I did it myself
    My Build Thread
    Apr 2011
    Lynchburg VA
    393
    I think I would wait until the pumps is up and running before I added anything. You will need to add CYA and chlorine and I would want the water circulating before I added those things. I guess you could add some chlorine now provided you could get it circulated through ot the pool well enough but the affects would be short lived without any CYA in there.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2010
    England, UK
    156
    I put in some chems when the pool is about one quarter full - but pre-dissolved in a bucket because the water is rather shallow at this point. It seems better than just letting the water stagnate until it's up to the skimmer, which is about three days for me as well. I use dichlor on start-up so that I get a little CYA into the water too. But other people probably do different things.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    FastCougar's Avatar
    Jun 2011
    99
    I take it that I have to go to the pool store to get dichlor ... was hoping to avoid that place right off the bat
    My Build Thread
