Thread: Need help on my dads pool....
    Apr 2011
    Central Texas
    20
    Guys, I thought I could clear this pool after everything I learned here... No Go! We are in WSW Texas Uvalde/Del Rio. The pool is cloudy and cannot see the bottom, much less the 2nd step. You can pull a sample and it is clear, and you can literally watch the limestone settle on the steps.
    He bought a pool for the grandkids and while it was filling he noticed the well was overloaded and was sucking limestone dust straight through the hoses.
    I tested the water and everything is good..... 4FC <.5CC 7.4pH, 110TA, 350CH 0SOYA
    Closest place to get CYA is 100 miles out and it is on the radar. Other than that this pool is perfect and holds Chlorine overnight. How do I wet rid of this microscopic dust. Its not "part of the water", its just suspended and looks bad.
    The pool is an Intex 16'*4' and it does have the basic filter. A new filter may be on the horizon, but this is what I need to work with for now.
    ~7000 gallon Intex AGP
    2650-Gallon Intex Sand Filter/Pump/SWG combo with Borates.
    Hayward AquaCritter
    Sep 2009
    Greentown, IN
    914
    Re: Need help on my dads pool....
    Hmmm... not sure with a cartridge filter there's much you can do to get that out of your water. May have to invest in a sand filter or such sooner than later....
    Maybe someone else will have some other ideas for you.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
