Results 1 to 11 of 11
Thread: pool water into spa
    New Brunswick Canada
    819
    pool water into spa
    I am not sure if this is possible or not, but here goes my question.
    I currently have an in ground pool with sag.
    In my new spa, I am using a 2 part bromine system, combined with a swg? The swg helps in keeping the bromine constant while we are not adding spa pucks after use.
    I find this spa is easily twice as much work as my pool and want to convert it over to chlorine.
    Can I use the water already in my pool, which cya levels of 60, and put it in my spa? I would then simply add bleach after each use.
    Secondary question would be, can I then retrun that water back into the pool when I wanted to change the water out?
    Any help would be appreciated as BBB has me running my pool on less then $100 a year.
    Rik
    22,553
    Re: pool water into spa
    I wouldn't do either. If you drain the spa into the pool you will turn your pool into a bromine pool and you'll have to do a 100% drain to get rid of it.
    819
    No, I am meaning to drain the spa, clean it, then add the water from the pool
    22,553
    I missed the part about you wanting to convert the spa.
    That would work then.
    819
    could I then redumb spa water into pool...or would u throw it out at say 4 months?
    22,553
    I would plumb it so I could pump it back and forth if it's feasible.
    819
    I can do it with a submesible pump. spa is only 5 feet from pool.
    I am thinking the water from spa, would easily be handled by the pool, then I could get fresh balanced water back into spa very easy. Just need to heat it back up...both would have cya an salt in it
    Mar 2007
    San Rafael, CA USA
    12,082
    Since the spa is isolated, I'd just run it Using Chlorine in a Spa. The water should last a reasonably long time depending on bather load, but I'd dump it and use it for watering lawns or other areas (mix with other sprinkler water to dilute the salt). Adding it back to the pool just adds the built-up organics which eventually would require some pool water dilution though perhaps that happens with backwashing and rain overflow. You could use pool water to fill the spa.
    You might want to only use half pool water to fill the spa so that your cyanuric acid in the spa ends up at 30 ppm instead of 60 ppm.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by JamesW
    Good point. I forgot about that CYA difference. It'll also be nicer having at least half fresh water in the spa anyway.
    819
    Thanks to everyone that replied, I will be doing the change over soon.
    Very much appreciated
