Thread: Solar Cover and Chlorine
    Should I remove the solar cover when adding liquid chlorine to pool? If so, how long do I leave it off?
    Location - Northeast Indiana
    15,000 Gallons (17x29) Above Ground - 1 HP Sta-Rite Pump - Cartridge Filter - Hayward Aqua Bug pool cleaner- Solar Cover
    TF100 Test Kit
    22,548
    Re: Solar Cover and Chlorine
    I would recommend removing it if you very concerned about it. It probably won't damage it enough to tell if your return is pointed downward. I usually leave mine on but I'm aware that it may be damaged and I choose to take that risk.
