Thread: shocking question?
    shocking question?
    Using the BBB method with regard to shocking
    cya 80
    fc 8
    Shock level is 31
    My question is do I subtract the already fc of 8 from 31 and raise it 23, or do I add raise it 31 over the already fc level of 8.
    Also how often do you need to shock..I know its basic questions, trying to get away from the Wally World of doing things Thanks and HAPPY 4TH
    Re: shocking question?
    Use the Pool Calculator, enter pool gallons at top, other details at bottom. In NOW column for FC, enter 8.0, for TARGET enter 31.0. It will tell you how much bleach or whatever chemical you select, to use to add the 23 ppm you need to get from 8 to 31
    You will want to consider going over 31, since you want to keep it at 31 all the time, never below. So go to 34 or something, so that you have some chance of keeping it at shock value as organics consume the chlorine.
    Butterfly's Avatar
    South Carolina
    10,045
    Also how often do you need to shock..I know its basic questions...
    Good question and one that is almost always misunderstood by newbies learning the BBB method.
    We only shock our pool when the pool needs it, ie CC 1.0 or more, cloudy water, flat looking water, green water, some reasons are very obvious
    But, when we do need to shock, it is a process and not a one time event. IOW, we bring the water to shock level and maintain that shock level as best as we can until we meet three criteria. The three criteria tell us when we are done shocking: See Red lines in my sig.
    In case you haven't seen it, here's a link to "How to Shock Your Pool" in Pool School:
    pool-school/shocking_your_pool
    You're done SLAMing when:
    Thanks for the replies , I knew there was someplace on how to I just couldn't get the brain to find it, trying to get the learning curve going with this and once I figure it all out its goodbye to those pucks...This is a great forum, and its people lilke you all that make it that way
    30,426
    Butterfly,
    That is a GREAT post! Should be required reading for ALL newbies!
