Results 1 to 9 of 9
Thread: Jandy neverlube and flex hose interior/exterior sizes
    Sarnia, Ontario Canada
    162
    Hi guys. I am ordering the valves and unions for the pump pad and I have a question with regards to tigerflex flexible pipe sizing and which size of jandy valves to buy.
    The valves are listed as 1.5/2 or 2/2.5. I assume the latter would have larger internals and be less restrictive, correct?
    I understand that the two diameters refer to the piping that will fit within the socket and that which will fit outside the socket.
    So do the interior and exterior dimensions of 1.5" and 2" tigerflex, match up with that of PVC pipe? Ie, if I am using 2" tigerflex, it will fit over the outside of the 1.5/2 or inside the 2/2.5, correct? Given the choice, i assume the tigerflex on the inside of the 2/2.5 would be the best way (least restrictive). In my mind this may be better under pressure as the flex hose is on the inside and is captured by the valve socket which won't allow as much flexing.
    Is my thinking sound?
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
    Re: Jandy neverlube and flex hose interior/exterior sizes
    Yes, you are correct. The difference between the two valve sizes is small, but the larger one is indeed less restrictive.
    Quote Originally Posted by armstrr
    When using the outside of the valve, you use a coupling to go onto the valve and the pipe goes into the coupling.
    The 1.5/2 valve has the same inside diameter as the outside diameter of 1.5 inch pipe and the same outside diameter as the outside diameter of 2 inch pipe.
    Support the site
    162
    Ahhhhh. Thanks to both of you. .
    South Central NJ
    3,192
    Remember this picture in 10 years. I don't like flex.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Just an FYI check on the price of Pentair valves ($24) vs Jandy ($44) the savings may interest you. Pretty much the same valve.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by AquaDoctorLLC
    My 2004 pool was built with Pentair never-lube type valves. Last year the cover o-ring popped, leaving a 1/4" gap and caused a nasty suction leak. This is a non-wear seal, it's just the cover that never moves.
    It's a very thin o-ring and I consider it a design weakness. I have no idea if this problem is common. That said, otherwise I have been happy with them.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    South Central NJ
    3,192
    Pentair's, Hayward's, and Jandy's all have an o-ring to seal the top to the body. If left undisturbed, it doesn't have a problem. When you remove the cover and then put it back without any lube like Magic Lube or Jacks, its not a surprise when the o-ring goes South.
    Scott
    162
    I ordered 8 of the pentairs 3 days ago. I hope it was a good decision. I noticed the neverlubes are PVC and the pentairs I ordered are PVC . I guess cpvc is better?? I say that because there is a line of pentair valves that are cpvc and they match the neverlubes pricepoints....
