Thread: Any DE go back in pool?
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    I get a powdery substance that settles on the bottom of our pool that forms in lines or streaks. It's usually a brownish color but I noticed after cleaning my DE filter that now it is gray/white in color. It's not a lot, hardly need to vacuum once a week, but I'm now wondering, is it normal to see some DE/dirt back in the pool?
    I don't believe there is a defect. This is my 3rd Haywood DE filter and our 2nd pool and I've always had to deal with this issue. I also never see any damage. ??
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,049
    Re: Any DE go back in pool?
    If you only get it after cleaning, I wouldn't worry. It's just residual in the lines. Maybe you need to flush a little longer.
    If it happens all the time, I'd say you have a torn screen or a cracked manifold.
