Results 1 to 12 of 12
Thread: Drain screws broken off?! How to fix???
    Jul 2011
    Phillips Ranch/Pomona, CA
    5
    I recently purchased a house with an in ground concrete pool (pool is filled with water). I noticed the drain cover was not affixed and upon closer view noticed that the drain screws are broken off, making the cover not stay on. Even though i'm in Southern California, where literally everyone has a pool, I can only imagine this could cost alot to have a pool professional come out an d fit it. Do I have to drain the pool to drill out the broken off screws or can I use some type of underwater epoxy to glue the drain cover on?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Drain screws broken off?! How to fix???
    Is there enough to grab with a vise grip pliers?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Jul 2011
    5
    unfortunately not....
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I guess epoxy is going to have to do. Personally I wouldn't do it. I would ez-out the screws. But it's going to require allot more time and effort! And an air tank!
    Jul 2011
    5
    The screw heads are completely shreared off. There is nothing to work with in terms of trying to using needle nose pliers to get them out. So going that route is a mute point. And I don't have an air tank. Even with an air tank, I would need some type of underwater drill to drill out what is left of the existing screws. So I guess epoxy route is the only one I can take. With that said, which epoxy should I use?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I wonder if an air drill wouldn't work underwater? You could probably find one cheap enough to experiment with at Harbor Freight. If the cover is like mine, it will fit anywhere in the opening, so what's to stop you from drilling a couple new holes next to the sheared-off screws and using some new stainless steel self-tapping screws?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    No, an air drill will not work underwater! You have to use the old fashioned egg beater! It works trust me! I can take out screws that are broke out below flush, do it all the time. How old is your plaster? New plaster in the future?
    Jul 2011
    5
    Quote Originally Posted by maxepr1
    Help me out here.... What do you mean "old fashioned egg beater"? How do you take out screws that are broke out below flush UNDER water? The plaster is older, but I don't have any plans (or the funds) to replace it anytime soon.
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by socal_pomona
    Jul 2011
    5
    Does anybody know a person who can fix my pool drain (i.e. drill out two broken off screws) WITHOUT draining all the water out at a reasonable price in the Pomona(Phillips Ranch)/Diamond Bar area?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Quote Originally Posted by Richard320
    That's right Richard! Take it down, drill in the center of the broke off screw with the correct bit for the easy-out you are using. You only have to drill down until the easy out can grab. Then use a tee handled tap tool and then back out the broke off shank.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    If you use a left-twist drill bit, you may not even need the easy-out.
