Thread: how to add baking soda or borax
    Jul 2011
    Greenwood, Indiana
    42
    I'm just educating myself so I'll know how to do this once I'm sure my current algae nightmare is cleared up....
    so when I need to add baking soda or borax, how do I add it and where? Deep or shallow end? just dump it in the water? put it in through the skimmer?
    Trying to figure it all out!
    Thanks!
    18,000 gallon in ground SWG sand filter electric cover
    22,548
    Re: how to add baking soda or borax
    Mix it in a bucket of pool water and pour it in front of a running return. You can also slowly pour it into the skimmer with the pump running.
    Butterfly's Avatar
    South Carolina
    10,045
    You have turned into a full-time student! It won't be long before you are out here helping newbies with their pools!
    You can learn about the chems and ways to add them to the pool water in Pool School here:
    pool-school/recommended_pool_chemicals
    Also, since you have an SWG, I doubt you will need to add baking soda (to increase TA) or Borax (to increase pH).
    Usually, with an SWG, the opposite happens and you are using MA to lower them!
    You're done SLAMing when:
    Jul 2011
    Greenwood, Indiana
    42
    Thanks Butterfly! I already bought some Borax so I guess I'll look into the other uses for it! ha!! Thanks for the responses..... where do you get muriatic acid other than the pool store?
    Jul 2011
    Greenwood, Indiana
    42
    Ignore that last question.... I see the answer in the link you posted....
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Kimmisue
    Lowes, HD, hardware stores....sometimes in the paint section, sometimes pool section, sometimes outdoor section You might want to ask or plan on doin' some walking
