Thread: Where is filter pressure info?
    Jul 2011
    Greenwood, Indiana
    42
    I can't find information about what it should be and when to backwash. Pool store told us to just do it once a week and we'd be fine, but I'm learning quickly not to trust the pool store. So, how do I know? Current pressure is about 22.
    18,000 gallon in ground SWG sand filter electric cover
    Re: Where is filter pressure info?
    A good rule of thumb is to backwash/clean the filter when the filter pressure goes up 6 psi above it's clean filter pressure. In almost all cases once a week is way too often, though the actual frequency of cleaning depends a great deal on the relative size of your pool and filter.
    There is no standard pressure. Every pool has a different starting pressure.
    Butterfly's Avatar
    South Carolina
    10,045
    You should also check your owner's manual for specific info., but generally backwash when psi increases about 6 above clean filter psi.
    Check Pool School under Pool Equipment. Maintenance and Cleaning of filters :
    pool-school/cleaning%20pool%20filters
    Edit: Changed psi info from 8 to 6
    You're done SLAMing when:
    Jul 2011
    Greenwood, Indiana
    42
    so once I backwash and rinse, will that give me my "starting" pressure?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Kimmisue
    Yep, you are correct.
