Thread: I need a timer or a different CompuPool model ... help!
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    I recently purchased a CPSC36 for my 27' AGP because it's more than double the capacity based on volume and the pool sits in direct sunlight. This is a fresh build (currently filling with water) and I was hoping to wire everything up, but to my dismay a few days ago I discovered I got the wrong model. I got the inground unit pre-wired for 220v, but doens't have the pump plugin/timer functionality of their above ground unit. I called CompuPool and they were excellent with me on the phone. We walked through some different options and it looked like they were going to send out a replacement panel unit. I then got a call the following morning from another customer service person at CompuPool and they informed me that the CPSC36 is no longer made for AGP with the built in pump timer, but that the CPSC24 would work for my needs as it still has the pump plug & timer. However, I went back to my vendor and they want to charge me a 15% restocking fee (bough on eBay), which ... you guessed it ... cost a little more than the difference between the two unit after you include my return shipping costs. So, I have 3 options as I see it ... get a timer/controller, eat the loss and overpay $100 on a CPSC24, or sell this unit and buy a CPSC24. BTW, I'd love to sell this on here, but don't see a classifieds section. What would you do?
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    Re: I need a timer or a different CompuPool model ... help!
    You can post non-commerical sales in the Coffee Bar area. Please ask people to contact you via PM and post when the item is no longer available.
    You should be able to reconfigure the unit for 120 volts and add an external timer that controls both the pump and the SWG. If you can figure that out, it is probably your best choice.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    FastCougar,
    I don't know if this helps or not but, I just bought the CPSC36 myself and while browsing the manual I saw it has an internal or external timer option. Meaning the unit can power itself on and off, or it can be operated by an external pump timer. (Manual page 5, #7)
    Also on page 9 of the manual, it says you can change the unit to a 120VAC by moving some jumpers around.
    CPSC36 Manual
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    FastCougar's Avatar
    Jun 2011
    99
    Thanks WestSide ... I just didn't want to spend any more money on a timer if the CPSC24 has the pump plug and timer built-in. So, I'm going to sell this unit (brand new, only opened to inspect) for a small loss instead of taking a 15% restocking hit from the vendor
    My Build Thread
