Thread: when to install skimmer on fresh build?
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    I have my fresh build filling with water now ... it's slow going due to using only a single garden hose. However, this is giving my time to figure out a few things dealing with the plumbing. This is a 27'x52" AGP and it's only got about 10" of water in it now (been filling for 15 hours). 3,500 gallons in thus far. At which point do I begin to consider hopping in and installing the skimmer & return and plumbing up the filter/pump? I have heard 1/2 way full, I have also heard 2-3 inches below the skimmer/return holes ... is this something I can do now or is it way too early?
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    Apr 2010
    Western North Carolina
    44
    Re: when to install skimmer on fresh build?
    I waited until the water was just below the return. That way you know that the liner has stretched all it is going to. I would be excited to! Do you have your equipment pad ready yet? That is something that you could work on in the mean time. Are you hard plumbing? You could work on that. And if all else fails, just ask your wife for something to do. If she is like mine, she always has something for me to do!
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    I have done it from 12 to 6 inches below the bottom of the skimmer opening. You want the most stretch with liner --this way as you continue filling the liner will not move too much from this position.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    FastCougar's Avatar
    Jun 2011
    99
    yeah, I'm getting ready to run to Lowe's to get some PT 2x6's and PT decking boards to build the pad ... I want to hard plumb, but I got the wrong SWG so I'm going to have to open the pool without it for now and do the BBB method until I get the right unit, so hard plumbing will also have to wait. Trust me, there is plenty to do: Build a retaining wall for a 1' drop around the "high" side of where I put in the pool, prepare the filter/pump pad, design and build a garden shed for my lawn tractor, etc. I like to keep myself busy so the wife doesn't have to
    My Build Thread
