spock
0
Jul 2, 2011
2
Ok..heres my problem....
I have a Hayward filter/pump for an above ground pool.
The model number for the pump is sp1580Z2
I have unfortunately lost the part which is the screw that you screw in against the wire at the end of the pump.
By screwing this nut in, it ensures a solid connection between the current and allows the pump and there for pool to run.
This nut would be screwed in right under the on/off switch on the pump.
Please help me find a replacement part...either a part number or the size of the nut that i need and hiopefulyl i can hit home depot.
Thanks to all in advance,...
