Results 1 to 9 of 9
Thread: Time between Chlorine and Muriatic Acid
    Just filled our pool and have added 1/2 gal Liquid Chlorine. Our ph is a little high, how long after adding the chlorine should I wait before adding Muriatic Acid?
    Location - Northeast Indiana
    15,000 Gallons (17x29) Above Ground - 1 HP Sta-Rite Pump - Cartridge Filter - Hayward Aqua Bug pool cleaner- Solar Cover
    TF100 Test Kit
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Re: Time between Chlorine and Muriatic Acid
    someone will be along to answer your question. Be patient, they may be using their pool or enjoying a family get together this lovely holiday weekend. BTW, Welcome to the Forum!
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Butterfly's Avatar
    South Carolina
    10,045
    30 minutes between additions, with pump running, should be fine.
    You're done SLAMing when:
    30 min with good circulation or add at far ends of the pool. If it is a small pool, circulate, if it is a big pool, add one at the deep end, the other at the shallow end. Both are added slowly, pouring over a return.
    Thanks, I am so excited to have found the website.
    TF100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by dshockney
    Oh! and welcome to the forum
    We're glad to have you
    Yes, super cool. In just a few months you will be bored with your pool. You test every day or so, you add stuff based on the Pool Calculator. It is always beautiful and blue and clear and clean. No excitement, no dumping of cash at the pool store. Nothing to talk about at the water cooler at work. It's like you need to find an entirely different hobby, there is not the drama with your pool that everyone else seems to have. Shoot, you may need to build an outdoor grill area! Or adopt a dog. Or let your mother-in-law move in. We need some drama here!
    Just ordered my TF100 Test kit today, I think I have some time before boredom reaches the point where I will be asking my mother-in-law to pack her things
    TF100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
