Thread: New Filter
    New Filter
    I have an 18ft easy set Summer escapes pool. The filter that came with it wasn't sufficient and I just got an intex 1500 gph filter. I know I should have asked before buying it but does anyone know if the holes are the same size? Should I just switch hoses and leave the existing outlets in there or use the much nicer ones I got with the intex pump? Also do I have to drain below that level to change them or just to it quickly with water escaping?
    Thanks!
    24x52 above ground
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: New Filter
    They are likely the same size, but you could measure just in case and compare.
    I'd just hold something (get a helper) over the inlet on the inside of the pool, expect a little water to come through and work fast.
    You could always do double like we do too. Use the old pump to supplement the new one. Since you have it and all... It seems to help increase the swirl/movement of the water a lot. Most debris ends up in the center of the pool.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
