Thread: cartridge filter
    Jul 2010
    Connecticut
    12
    cartridge filter
    Seems like every year I battle an algae problem or pollen, or tree droppings and the cartridge gets ruined. My cartidge is a year old. I recently ended a bout with algae and now the cartridge has a slimey coat of dead algae on it, a grayish slime. The pressure gauge on the filter is showing nearly double the pressure...from a normal 10 lbs up to 18 now. I am now letting it soak in a dish liquid mix overnight. If that doesn't clean it should I try the muriatric acid cleaning ? Replacement cartridges I have seen on the internet for about $120.00. Who has the best prices on them these days ?
    30 ft. round 52" deep above ground pool, about 20,000 gallons
    Starite cartridge filter with 1.5 GPH pump
    Re: cartridge filter
    I use the hose to clean my cartridges.
