Thread: With robot cleaner do you run your pump?
    I'm new to the Polaris 9300 this season and I have a 2 speed pump which i run 24 hours on low speed. When you all put in your cleaner do you keep your pump running or do you turn it off?
    Also, when you connect the cable to the power center does yours screw all the way on the threads so you can't see anymore threads. My doesn't and I know the way it gets pushed in as I see the little square tab on one side. It still works but it seems hard to screw on and threads show. Thanks
    15x30 In ground vinyl liner, 16000 gallons. Sta-Rite Sys 3 Cartridge Filter (S7M120), Aqua Comfort Heat Pump Model 110, Sta-Rite Max-E-Pro 1.5HP 2 Speed Pump (Model P6RA6YF-206L), Loop Loc Mesh Winter Cover and always use Solar Cover. Polaris 9300 Sport Cleaner, Taylor K-2006 Test Kit.
    Liquid Super Chlor 12% (Sodium hypochlorite)
    Jul 2007
    Chicago, IL
    87
    Re: With robot cleaner do you run your pump?
    I don't have a Polaris, but do have a Aquabot. I've not had an issue running the pump at the same time the robot is cleaning. I initially thought he may get caught on the main drain, but no problems at all.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Oct 2010
    Eastern TN
    172
    I run my pump 14 hours per day and the Polaris runs when the pump is on.
    I have the remote Polaris and the power cable fully covers the threads.
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Oct 2007
    Parkland, FL
    752
    pump on or off should have no affect on the robot, it works independently, I suppose it could get stuck on main drain if you are suctioning from there, I just use skimmer.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    kenandshari's Avatar
    Aug 2010
    Savannah, GA
    134
    We have a Nitro Wall Climber robot and run our VS pump (low RPM up to 3000 RPM) while Nitro is in the pool with no issues.
    Ken & Shari
    Savannah, GA
    16' x 40' freeform fiberglass inground (Pacific model, mfg by Tallman Pools), 23k gal, 2" plumbing throughout, Intellichlor IC-40, Easy Touch controller, Intelliflow VS 3050 pump, Pentair Clean & Clear Plus Quad Cartridge filter. 4 Jandy deck jets (3/4" plumbing), Fiberstars color changing lighting, SR Smith salt friendly diving system, Interfab Wild Ride slide, Aquasol Solar Heat (5 panels 4'x12' DIY install automated with ET) RIP Nitro Wall Climber Mar 2011-Aug 2012, Nitro is survived by a Polaris 360.
