Smoking hot pool water
Hi,
I saw this thread and thought I may not want to do the acid outlay to keep up with the pH. But my pool is running around 90!
How about this?
I build a couple of these gadgets and switch my pump running from day to night.
Any problem with not running the cleaning and filtering during the day?
Or maybe set a cooling pump cycle for so many hours at night.
Would be cheaper than a chiller and might work as well if done right.
No problems running at night. Actually running at night will work better for cooling, at least for me. I get 9-11* drop at night, I was only getting 5-6 during the day. Humidities were below 30%. Chillers are much more costly.
Just curious how these 2 part stay together? Is the male end simply inserted and it stays or something else?
Ah, forgot another piece...
Curious what kind of pH increases everyone is seeing. I have a raised spa / spillway ( spillover set real low) which I think is the reason my pH always creeps up ( 16 oz acid per week at least ). Would like to build some misters also if pH will not go crazy high.
