Results 1 to 9 of 9
Thread: Weekly chems
    Jun 2008
    new jersey
    49
    Weekly chems
    New owner, swg pool. Are there regular chemical additions such as algaecides or clarifiers that should be a regular part of maintenance? Say a few oz per week?
    Numbers good but should I add something to prevent something...
    29,500 unite, swg, spa, cartridge, Polaris 380
    Also, any issue of salt loss over winter with a mesh cover?
    Thanks
    29,500 gallon freeform gunite pool with 3M quartz plaster. Hayward/Goldline cartridge filter, SWG, gas heater, aqua logic PS/8 automation.
    22,550
    Re: Weekly chems
    Your best place to start is to begin reading Pool School again on the care of an swcg pool.
    A good test kit is all you need to add regularly if you don't have one.
    Sep 2009
    Greentown, IN
    914
    Re: Weekly chems
    With an swg I would have at least...
    a good test kit
    chlorine for the occasional additions (I bump up chlorine sometimes after a high bather load)
    Muriatic acid -swg pools will occasionally creep up in ph
    salt... whatever is required for your swg
    No algaecide or clarifiers ... If you manage your levels correctly you shouldn't ever need them.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Oct 2010
    Georgia
    317
    Re: Weekly chems
    Algaecides and clarifiers are not "regular chemical" and are not needed.
    "Numbers good" does not tell us anything useful. What are the numbers?
    Here is some additional information on Salt systems:
    pool-school/water_balance_saltwater_generator
    The salt won't evaporate over the Winter, but draining and replacing with rain water or fresh water can lower the saltinity.
    The optimum level of salt for the Aquarite salt system is 3200 but will operate from 2800 to 3400. The LCD display on the Aqualogic should show the salt concentration.
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Jun 2008
    new jersey
    49
    Re: Weekly chems
    My numbers fall into parameters of swg water specs. I am on that all week. I do add muriatic acid daily as ph is a constant fight to keep down, other than that and keeping cya up to specs I haven't needed to do much else.
    Someone told me solid is the way to go vs a quality mesh due to the need to add salt each opening to to rainwater. Thanks for comments...
    Mar 2009
    eastern washington state
    275
    Re: Weekly chems
    if you could post a full set of numbers. I am sure someone will be able to help you out... All of the numbers play a part in a well balanced pool. its just very helpful to have a full set of numbers.
    good luck.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Jun 2008
    new jersey
    49
    Re: Weekly chems
    Fc. 5
    Ph. 7.6
    Ta. 60
    Cya. 70
    Ch. 240
    Salt. 3200
    22,550
    Re: Weekly chems
    Doesn't look like you need to add anything to that pool but people!
    I'd probably keep a bag of salt and a jug or two of bleach on hand. You won't need anything weekly but you want to have a little salt and bleach on hand to handle any issues that arise.
    Jun 2008
    new jersey
    49
    Re: Weekly chems
    Thanks. I keep clorox, baking soda, and muriatic acid on hand. I need to keep the ph down as it creeps up daily.
