Thread: air bubbles spa return
    Hi - we just had a pool/spa built, 20,000; spa level with pool. shared variable speed jandy pump. venturi tube, no blower for spa.
    I'm noticing, even at low speed, air bubbles coming out of 1 spa return only - is this most likely related to air from venturi effect or might I have a leak? air not coming out of any of the pool or other 3 spa returns...
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Re: air bubbles spa return
    If you have a salt water generator, when the cell comes on, you will see air bubbles coming out of the nearest return.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    22,548
    It could be the venturi. While they don't work well at low flows it could be pulling a little air into the system. If you shut all the spa returns off does any air come out of the pool return(s)?
