Thread: drain or clean
    drain or clean
    For a AGP with an algae problem from day 2 (put water in before we got salt water system set up!),
    is it easier to drain the water and start over or try to kill the algae? Thanks.
    intex above ground ultra-frame pool 8,000 gallons, sand filter, salt water generator, new 2011
    30,431
    Re: drain or clean
    Welcome to the forum It is easier to kill the algae but it will require you to read How to "Shock your Pool" up in Pool School.
    Shock the pool exactly as that process says and your pool will clear up.
    If you just drain and refill, the same thing will happen again.
    Re: drain or clean
    I didn't believe it, but it did turn green to white this weekend. (Once I finally read the pool calculator correctly --didn't realize shock meant I had to input a goal of 15)
    Dropped back to FC near zero though, so not sure I have it there yet.
    Feb 2008
    Denton, TX
    5,061
    Re: drain or clean
    You are finished shocking when your FC holds to within 1 ppm or less of loss overnight, your CC is < 0.5, and your water is clear.
    Re: drain or clean
    Do you have any stabilizer in the pool?
    Sep 2009
    Greentown, IN
    914
    Re: drain or clean
    You can do it!!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
