Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Please help walk me through this...
    Opened the pool this year, if any of you remember me from last year all I did was fight with the pool.
    This year we drained completely did some maintenance refilled, etc. to find the pump was ready to retire. Ordered a new pump and sand filter, but of course in the week and a half it took to arrive... swamp happened.
    I'm so frustrated and my husband can't understand. We are having company in two weeks and feel like I'm losing this battle.
    ABG, 24'. We have a SWG but it's not hooked up currently. If you guys think it will help I can do that.
    Just checked the CYA is at 30, I put 1 lb of stabilizer in the sock.
    Chlorine is 2 and O... simply amazing to me as I put in 2 gallons on chlorine a couple hours ago.
    I have the next 24 hrs at home, then have to work. During that time my husband can put what I tell him to in when needed, but he doesn't "play with the chemistry kit" as he says.
    I am running to the store to stock up on bleach, I put my last gallon in just now.
    ETA: I have been vacuuming best I can, I'm going to order an "automatic vac" deal to help as well.
    Owner of a cloudy but no longer swampy green AG 24' x 4' Doughboy, sand filter with SWG. Soon to be a crystal clear oasis!
    22,553
    Re: Please help walk me through this...
    Keep it at shock level as often as you can and go ahead and hook up the swg. It won't keep it at shock but it'll help. Do you have the salt in it?
    We don't have salt in right now, but I can get it in.
    Okay, I added the 400 + oz of bleach per the calculator, and I need to check again in an hour right?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    yep :~}
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Mar 2010
    Spring, TX
    1,082
    The more you can keep at shock level the better. If he will not play with the kit, how will he know what the levels are to be able to add the correct amount of bleach?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Well he doesn't seem to care if the pool is green anyway. But I'm hoping to get a good 24 hr shock in before work, and my neighbor will probably come and check it twice while I'm at work if I ask her her dad has a pool and I'm pretty sure she knows how to work the chemicals if not I can show her and the box has instructions of course.
    Okay for our 1 hr check we're at 2.5 FC, 2.5 CC. So we kept a little. I'm going to add another 3 gallons per the calc.
    Anything else I should be doing? They were swimming before I started this so everything was mixed around really well. I always tend to try to add MORE than the calc tells me... other than wasting money is this going to hurt anything?
    It really sucks when I seem to the be only one who cares if the pool is clear or not, I really appreciate all of the comments.
    Butterfly's Avatar
    South Carolina
    10,045
    We'll stick around with you. Hit it hard! ...and since you're the one working, here, this is for you
    You're done SLAMing when:
    Hour check in.... I think we're getting somewhere!
    FC 7.5, CC 1 Atleast the FC is getting up there now!
    What's the best plan of action for night? I can keep checking from when I go to sleep until I get up, but for overnight just do an overnight test or.... ???
    Keep the FC at 40 % of the cyanuric acid until all of the CC is gone (less than or equal to 0.5 ppm), and the FC only loses 1 ppm overnight. If your cyanuric acid is 30, then your FC needs to be 12 ppm.
    Support the site
    Okay, our 8:30 shows we have a FC of 18, CC of 1.5.
    I must've over done the bleach... lol. So now I just keep monitoring right? I will probably try to sweep again before night if the drones ( code word for gigantic mosquitos ) don't carry me off!
    I was also thinking about adding DE to my filter. Thoughts on that?
    Correct, continue to monitor. You're doing well. As long as the filter is increasing in pressure and the backwash shows dirty water, then it's too early for DE. Once the filter pressure stops rising as fast, then Adding DE is a good idea.
    Support the site
    Mar 2010
    Spring, TX
    1,082
    Just keep at it. When you do your final test of FC for the night write that number down and do not add anything else. Check again in the morning before the sun comes up and post your final result from last night, result in the morning. Post the FC and CC for both of those.
    This morning's reading were
    7 FC 1.5 CC
    The PSI never gets about 6, the new filter came with this gauge, but it doesn't rise or drop really. I've been backwashing daily, or when the flow seems decreased. I always get plenty of green out and it runs better when I'm done.
    As for a visual, we're completely milky, no green. I brushed and brought up some debris but no green really.
    So I added bleach to bring it back up to shock, and I keep it at shock until my over night doesn't drop significantly or I'm at .5 or less CC's right?
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    You have to keep shocking until you have no overnight loss AND CC of .5 or less... and a clear pool. Hang in there.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    We can barely see the 3rd rung of the stairs. Sweep this morning brought up some "gunk" but nothing green and we're sitting at a milky blue color
    Morning's 9:00 FC - 7, CC 1.5. So we keep shocking.
    Thoughts on the DE? Will it help clear it out faster? Or just wait?
    22,553
    Have you passed the OCLT except for the clear part? If not then DE isn't going to help much. I'd wait till you pass the first two parts of the OCLT to add the DE.
    Still working on the OCLT, this morning we were down to 1 CC, so I'm hoping by tomorrow!
    We lost a little bit of clarity, but my husband stirred it up really good yesterday for me while I was at work and we had a pretty big drop in FC, but not a big rise in CC, which I guess is good.
    Should I try to vacuum tomorrow? I have not vacuumed at all since I started, I did right before though when it was still green. Currently no hint of green, not even in the backwash, so that's good at least!
    Jul 2007
    Chicago, IL
    87
    Sounds like you're making good progress. As a result, you're killing lots of algae. The dead stuff is likely sitting on the pool floor, so yes, vacuum as often as you can.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Blue is better than green! You're getting somewhere!
  20. Back To Top    #20
    Planning to vacuum tomorrow as I have the day off, then the rest of the week after Wednesday I'm off so plenty of time to vacuum, etc.
    The FC level keeps dropping pretty rapidly... I had it up to shock level before work, and after I got home ( about 9 hrs later ) it was down to 2 FC... should I be worried about this or is it just getting used up? The CC was at .5 or lower.
    Cant' wait to have a few days off and get this algae licked good!
