Thread: Sand filter with a little DE?
    Columbus Ohio
    178
    I believe I read somewhere that it helps with the small stuff the sand cant get? Is this true? Does it work? Our water is crystal clear but want to remove as much small partical stuff as possible... as well if it is possible, we have a 250 pound sand filter and how much DE would be needed? and how do you add it? Thanks!!!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Oct 2010
    Georgia
    317
    Re: Sand filter with a little DE?
    Here is the link in Pool School.
    pool-school/add_de_to_a_sand_filter
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
