Thread: how long till salt stabalizes
    Jun 2011
    Nj
    57
    i had the pool filled monday
    put salt in monday
    tuesday added some more to bring from 2600 to 3100 ppm as per the display on the aquarite unit
    wed 3100
    last night started it up when i got home 3100
    turned it off this morning befor work it was higher 3700
    i did not add any salt
    i will check when i get home to see if maybe it was a fluke
    but how long does it take for the salt to stabalize so i can get a good reading?
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Jun 2011
    Nj
    57
    Re: how long till salt stabalizes
    does water temp play a role in that?
    water temp has been 80*
    last night and this morning it was 78*
    Aquarite SWG system
    It can easily take 24 hours, occasionally as much as 48 hours, with the pump running before the salt level stabilizes after a salt addition.
    Jun 2011
    Nj
    57
    right i thought 24 hours, which would be tuesday night
    which is when i added more salt which would put me a wed night
    so thurs night would be 48 hours
    but this morning would be 10 more hours and it went up
    ill check when i get home from work, hopefully idont have another diff number
    Aquarite SWG system
    Ft Lauderdale, Florida
    1,455
    Make sure both your skimmer and bottom main drains are opened. If it's just drawing from the skimmer, the heavier salted water will tend to linger around the bottom of the pool.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
