Thread: Intermatic trippers - how to install
    Jun 2011
    Austin, TX
    33
    Just bought a home with a nice in ground pool. I have an Intermatic PF1202t dual circuit timer and I'd like to install additional trippers for a second pump run. It uses the silver and gold trippers with the small screw. How do I install these on the dial? Just reach up and insert them behind the dial or do I have to remove something first? Also, do I have to turn off the power first? Sorry if this is a really basic question, but I'm a new pool owner.
    Thanks
    13,500 Gallon Plaster IGP
    Hot Tub w/Waterfall
    Aqua Rite SWCG
    A.O. Smith 1.5HP Motor
    Hayward Sand Filter
    Polaris 280 with Hayward 3/4HP Booster Pump
    Apr 2008
    Central Texas
    326
    Re: Intermatic trippers - how to install
    Loosen the screw, slide the tripper in from the edge of the dial, then tighten the screw. It's really just that easy.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Jun 2011
    Austin, TX
    33
    Thanks! That is really easy.
    Hot Tub w/Waterfall
    Aqua Rite SWCG
    Hayward Sand Filter
