Results 1 to 7 of 7
Thread: Lost in NY
    Lost in NY
    Hello I guess i'm new to pools even since it I have lived at the house with one for 3 years the wife did most of the work on it now it's my turn. I guess I have a problem after 3 weeks I got the water blue, But it is still not clean thou. I took a friends advice and dumped a bunch of bleach in it 9 Gallons and then 14 1 lb of super shock. it's blue but like i told her the other day I hate the pool I spend more time getting it right then using it. I will see if i can get the testing kit I saw people talking about and try to figure out the specs on the pool. I will Try to play catch up on the pool school and wait to post questions.
    Thanks
    B
    Approx. 10,000 gallon pool
    salt water in-ground
    22,553
    Re: Lost in NY
    Once you get the test kit and get past this initial phase of getting whatever is going on fixed, you'll be surprised how easy it really is to keep it clear and sparkly.
    Take a sample of water to the pool store and post the results, and we can help get you started till you can get a good test kit.
    Sep 2009
    Greentown, IN
    914
    Re: Lost in NY
    It would be helpful too if you could put your pool specs in your signature line so those that try to help you know what you have.. makes a difference in chemical levels and such.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Feb 2008
    Denton, TX
    5,061
    Re: Lost in NY
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Lost in NY
    Welcome to TFP! Now you're found.
    Once you get the kit, things will go quickly. There may be one big outlay for pool chemicals, but after it's set, it will take very little to keep in sparkling.
    Trust us, it will not be long until you have this beast tamed. Then we can talk about fun pool toys and BBQ plans.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Lost in NY
    Quote Originally Posted by Bouoy
    .....but like i told her the other day I hate the pool I spend more time getting it right then using it.... B
    Well, that sure sounds like you got lost in the pool in NY, but you have now been found
    Like they said, we'll get you straight w/a little up front $$, then it will be smooth sailing...
    Welcome to the forum
    You're done SLAMing when:
