Hi everyone,
I'm still in the planning phase of my inground vinyl pool build and have a question about the IC40 SWCG and lights.
Equipment and specs going to be used for the pool:
40' x 23' vinyl with 3.5' to 6' depth
a. 1 x Whispherflow WFDS-6 1.5 HP pump
b. 1 x Triton II TR-100 600 lbs sand filter
c. 1 x Intellichlor IC40 SWCG
d. 2 x colorlogic LED lights
e. suction side pool cleaner
f. 6 x returns
g. 1 x slide
h. 1 x Foxx pools buddy deat
i. 4 x deck jets
j. 1 x Dual MD
The pump will be set to run on low 24/7 and only run on high when the slide, deck jets and or pool cleaner is running. I would like some more control out of the SWCG and lights than what I get with just the equipment. I'm not looking for anything fancy just a system that can control the lights and also have more precise control over the output of the SWCG. If I can add the pump to the system that would be fine to.
Any control system suggestions?
Pros and Cons?
Features I should have?
What would you have done different with your automation system?
f. 6 x returns
g. 1 x slide
i. 4 x deck jets
j. 1 x Dual MD
Pros and Cons?
