Thread: How long to I need to run the filter?
    I have a 15x48 pool, I think it's 4400 gallons. I have a hayward 1 hp pump and hayward 166t sand filter? How mnay Gallons does that pump do, I can't seem to find that info anywhere and how long would it take to recycle all the water?
    Thanks
    Vinyl 18x36 Single Roman End
    ~26,000 Gallons
    Goldline SWG T-15 Cell
    Sand Filtration
    Pool Tool Zinc Anode
    LaMotte Color-Q Pro 11 Test Kit
    Re: How long to I need to run the filter?
    It is difficult to say exactly how much water the pump is moving, as it depends on many details of your plumbing. Still, it should easily be moving 50 GPM or more, most likely more. That suggests that it probably takes less than two hours to do a turnover.
    my plumbing consists of 1.5 inch hoses. thats all. Also I am confused about seomthing. I have the pump hooked up to a GFI. Do I also need to ground the pump? What's the easy way to do it. It's at the back of the yard. I read I need to buy an 8ft grounding rod and push that into the ground and attach a grounding wire to it? Even on a GFI, I still need to ground it?
    ~26,000 Gallons
    Sand Filtration
    22,553
    You don't need to ground it. It's grounded through the power cord.
    Is the pool a steel walled pool? If it is you need to bond it and the pump and every piece of metallic equipment that either touches the water or is within 5' of the wall.
    no its an intex pool, bascially a big liner with metal posts holding it up.
    ~26,000 Gallons
    Sand Filtration
    22,553
    While I recommend bonding it anyway, there's no requirement for doing so.
