Results 1 to 7 of 7
Thread: Question On Adding Salt To Non-SWG Pool
    Mar 2011
    Grand Rapids, Michigan
    279
    I'm looking into adding salt just to improve the feel of the water. Pool Calc says to add 293 pounds for 2000ppm. So can anyone give me a ball park figure on how long this will take to dissolve? Days, weeks? Should I brush it around every hour or so to help it along? I will probably only start by adding 1/2 of the stated amount as I currently have no way to test for salt. Also I have used nothing but 10% Sodium Hypo for chlorine--does this make any difference?
    Latest test results 06.29.11/ Tf100XL
    FC 5.5
    CC -0-
    TC 5.5
    Ph 7.6
    TA 110
    CYA 40
    Thanks in advance and thanks again for all the help you have already given me with such a great forum.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    30,421
    Re: Question On Adding Salt To Non-SWG Pool
    Probably your best bet would be to get some salt test strips to give you a rough idea of how much you currently have and then how much more you will need.
    You are wise to start slowly and add more as you experiment. I have never used it but others on the forum report it dissolves quickly and easily by pushing it around with a broom.
    Mar 2011
    279
    Will do on the strips. Thanks, Duraleigh!
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    We have added salt to our water as well and I used the services of myself, a sis-in-law, and 3 nieces/nephews to help it dissolve. Dumped it in bit by bit and we pushed it around with our feet. Made sure we didn't step on it JIC it would be sharp and tear the liner (ya' never know...)
    The water feels wonderful and I highly recommend it to anyone who is on the edge about whether or not to add some.
    I also agree with Duraleigh, get some salt test strips so you know how much is already in there. Could be negligible, but then again....
    What a nice feel for the 4th!
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Hi Debbie,
    We have a 12,500 gal AGP and add several bags of salt each season. I've never tested for salt; I go by 'feel'. At the beginning of the season I put in 3 bags (120#) which gives me the silky water feel I like. Because we get a lot of splashout and have to replace water frequently I normally add another 1 or 2 bags as the summer wears on.
    In the past, we would just dump the salt in and swish it around with the brush or our feet. The warmer the water is, the faster it dissolves but even in relatively cool water it takes no more than a couple of hours.
    Our method this year was to put some 2" slashes in the bags and just drop them into the pool. They start to float as more and more of the salt dissolves. That method takes a day or two. It's okay but it deprives me of the incredible glitter you get from salt crystals in water with the sun shining on it. It looks like the pool floor is covered in diamonds
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mar 2011
    279
    Thanks for all the replies. Dumped 200 pounds in yesterday. Pushed it around with my brush and was amazed at how fast it dissloved! Could really feel the difference after the 3rd bag went in. Was looking forward to seeing my pool floor "covered in diamonds" but alas, my local weather forcasters must be stationed in sunny LA lately.
    Mine is usually dissolved within an hour. 30 mins if i brush it around.
    18,000 gal ig salt pool krystalkrete plaster 7x10 raised spa w/ 2 spillovers
    4x20 wet deck, waterfall, 17ft infinity edge, deck jets, nexxus lighting
    Jandy pumps & controls, Aquapalm PDA, 400k heater, Kleen Machine robot
    (6) 4x12 solar panels, clear solar cover
