Thread: Can I use Cal-Hypo only to chlorinate?
    Jun 2011
    las vegas nv
    7
    Can I use Cal-hypo and not use tabs? Outdoor pool in VERY sunny Las Vegas. Or do I need to use tabs to raise CYA? If so what do you think would be a good CYA level for a hot sunny climate?
    Inground plaster 20,000 gal
    Whisperflo 2hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Can I use Cal-Hypo only to chlorinate?
    You need some CYA in the water no matter what the source of chlorine. In Vegas, 60 or 70 wouldn't be outrageous.
    Cal-hypo, however, is another story. Every time you add it, you add Calcium. The water will evaporate, the chlorine will dissipate, but the Calcium remains forever. You'll be in quadruple-digits in no time, if you aren't already. A huge number of posters from Las Vegas post about scaling. Don't be one of them.
    Your two best options are bleach or a saltwater chlorine generator.
    I suggest you order up a good test kit ASAP, and immerse yourself in Pool School. Pool School has a good article on what constitutes a good test kit.
    Jan 2009
    Southern Nevada
    37
    You don't want to, our calcium level is 350 out of the tap and the evaporation is constant. CH is a battle to stay below 1000 in our pool. I only have scale to fight on my spill over from the wind and such but I use a lot of acid to keep the TA and PH in check, I would not use cal-hypo here ever.
    18,500 gallon, 16' x 38' freeform ig plaster w/ 7 ft spill over spa
    Pentair C&C+ 420 cart, Inteliflo 4 x 160 pump - new plaster on 5/5/09
    Jun 2011
    las vegas nv
    7
    Ok good info ......thanks much.
    Whisperflo 2hp pump
