Thread: left test kit outside all winter, CYA chem question
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Hi,
    I left my TF-100 test kit out all winter, can I trust the CYA test?
    I just tested for the first time this year & filled the tube all the way & it did not obscure the dot at all.
    No chlorine loss over night & no CC's.
    I was expecting the level to be 40 like last year, but it has been 10 months of rain since last year.
    I have been keeping the CL @ 7 like I had a CYA level of 40, but I have been l dropping to 3 after 8 hours of cool overcast weather, that is what made me test for CYA
    My question is, should I add enough CYA to get me to 20 while I wait for more reagents?
    Thanks
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: left test kit outside all winter, CYA chem question
    I was told by pool store guy, and I've read here that it doesn't go bad. I left mine in the garage all winter too (Portland). Two different test kits worth, one them has to be like 15 years old even. Both read the same results.
    Did you have a lot of spill over due to rain?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Bob_Funk's Avatar
    May 2009
    113
    Just checked my notes from last year, I never tested for CYA in 2010, weather was so bad the pool was only up for 6 weeks, CYA level of 40 was from 2009.
    Plenty of rain in the last 2 years, I had to add quite a bit of water to open in 2010, only an inch or so this year.
    CYA is probably near 0 now, the dot didn't even get to the level of the mid test pic in this link http://www.taylortechnologies.com/Chemi ... ntentID=44
    I am going to add enough CYA to get to 20 as I am burning way to much chlorine during the day with overcast skies & losing .5 at most overnight.
