Thread: Thanks for the Help
    Mar 2011
    Houston, TX
    72
    Thanks for the Help
    After four days my TA measured at 80 from 260. Can't believe it only took 4 days, completely expected it to take several weeks. I am the proud new owner of 6 gallons of MA which I am sure I will use over time but I haven't had to add in 2 days so I suspect these 6 gallons may last me a while.
    You guys are so smart. My pool looks awesome. New neighbor down the street is getting a pool installed next week. Already debating if I should teach them about BBB or just let them go with the PB recommendation. I get all sorts of funny looks when I say I use bleach as chlorine.
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Thanks for the Help
    The rule is that it takes 25-1/2 fluid ounces of full-strength Muriatic Acid (31.45% Hydrochloric Acid) to lower the Total Alkalinity (TA) by 10 ppm in 10,000 gallons. So going fro 260 to 80 in 18,500 gallons should have taken 849 fluid ounces or 6.6 gallons. However, from this thread it sounds like you only added 111 ounces to get from 280 to 150 and then 43 plus 71 ounces to get to 140 and then to 110 and then 80. So unless you didn't tell us about all the acid you were adding you added much less than expected. I wonder if your 280 reading wasn't correct. Static electricity can make the drops shoot out too small from the TA titrating reagent (R-0009) giving you a false high reading. Wiping the dropper tip with a moist cloth or tissue usually resolves that problem.
    Mar 2011
    Houston, TX
    72
    I didn't report all of my readings if the MA I added but I only used close to 3 gallons. I guess my original reading could of been off. Pretty sure I used the wet cloth but maybe I missed a couple times. Just glad I am within the correct range now.
    Sep 2009
    Greentown, IN
    914
    Glad you got such great results so quickly .. but who would have expected less? These people won't steer you wrong.
    If you do venture to tell your neighbor about BBB you may get some funny looks from your neighbor as well. Many will take it easier if you say you use "liquid chlorine" and then give them information about the site. Would be great if you and your neighbor both had trouble free pools! Good Luck
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
