Results 1 to 7 of 7
Thread: Evaporation and CYA
    Mar 2011
    Houston, TX
    72
    Evaporation and CYA
    Is it possible that over time and a hot summer my CYA could drop to within acceptable ranges in HOT Texas. I am replacing approximately 2 inches of water every couple of days. I would suspect that over the next 3 - 4 mos I will be replacing a significant amount of water. Really dreading the 60% water replacement. Any thoughts?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Evaporation and CYA
    Water evaporates. CYA stays behind. Whatever you read now, it will be the same when you top off the water.
    Mar 2011
    Houston, TX
    72
    Wrong answer Richard. I wanted you to tell me that over the HOT summer months I will essentially be replacing half of the water and therefore lowering my CYA. Maintaining FC at 12 is using quite a bit of bleach but the results have been well worth it.
    Dec 2010
    San Diego, CA
    1,137
    You will lose CYA with splashed out water...how much of your loss is from evaporation and how much is from use?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Mar 2011
    Houston, TX
    72
    Quote Originally Posted by carlscan26
    Really no way to know I guess. We have been using the pool daily for two weeks since it is brand new. Guess I should quit fussing at the kids for splashing all the water out.
    Dec 2010
    San Diego, CA
    1,137
    I keep some tablets on hand, and when CYA levels drop a bit, I switch over to bump it back up, then go back to bleach.
