Results 1 to 8 of 8
Thread: First time testing, please advise.
    Hi,
    I just received my test kit today and did my first test. The results are:
    FC 1
    CC .5
    CYA Does not register
    TA 40
    Ph 7
    I just added the Walmart brand stabilizer Monday night using the sock method. This is an Intex Ultra Frame 24' with the combined sand pump and SWG. I set up about two weeks ago and followed the Intex customer service advice. 1) Run the pump 24 hours first before setting the automatic operating hours. 2) Set the operating hours at 7 per book 3)Add CYA once temps rise above 90.
    Went out of town for two days after adding CYA and there is yellow algae starting to show on the bottom. Have ordered salt water test strips but have not received yet. Would you please guide me on what to address first? Thanks
    13K Gallons, 24' round vinyl, Intex 56681EG 120V Sand Filter Pump and Saltwater System, central Illinois
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,991
    Re: First time testing, please advise.
    Get some chlorine in there fast.
    How much CYA did you add? Meaning, what was your target? You need to get FC up to whatever shock level is for your assumed CYA level. That algae will soon take over the whole pool if you don't.
    That's still a whole lotta water even if it's ABG. Pre-empt the heartache and order up a proper test kit ASAP. There's a discussion of kits in Pool School, top right of this page.
    Thank you!, I just received the Taylor K2006 test kit recommended on this site and used it today. I was using the strips until today. I added a 4 lb bag of CYA. I believe it said 78% CYA on it.
    Richard320's Avatar
    Jan 2010
    18,991
    Okay, that means CYA is assumed to be 30.
    Shock for that is 18, according to Pool Calculator. That means 3.6 gallons of 6% chlorine bleach, just for starters! And more to maintain the FC until all the algae is killed. After the shock process is over, never let FC drop below 3 again.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Isn't yellow algae mustard algae?
    Time for a double tap?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Got it. Just added the one jug I had on hand and will get the rest in tomorrow. Thanks so much for your help.
    22,548
    If you're going to shock, you can't do it a little at a time. You have to add all that the Pool Calc says to all at once. then you have to test again and add the amount given you then by the Pool Calc all at once. And keep doing that until you pass the OCLT. You can't put a little in now and a little in later. You're just wasting chlorine if you do that! Not trying to be harsh but don't want you get frustrated and also wasting money.
    Not harsh at all. The advice I received here put me on the right track and now the pool is testing good in all areas. Thank you everyone for your help!
